t5 manual conversion Auto -> Manual (Urgent)
Page 2 of 2 [ 26 posts ] Go to page Previous  1, 2
 Post subject: Re: t5 manual conversion Auto -> Manual (Urgent)
Posted: Mon Jun 28, 2010 7:03 pm
Stock as a Rock
Gallery: 9 images
Ride: 1990 ea 5 speed
SA, Australia
oh and by the way acceleration is f**k amazing i didnt think they'red be much difference but its awesome mine spins through first n halfway through second in the wet is scary until ya get used to it so BE CAREFULL lol
89 ea falcon " panda" ef 5spd i6 engine with wade 1673 cam shaved ported head, full stainless 2 n half inch zaust 20 inch rims n 330mm brake upgrade soon to hae m90 blower running 12 pound pulley :D
Posted: Mon Jun 28, 2010 7:10 pm
Stock as a Rock
Ride: 1992 Ford Eb Series 2
mm yeh im used to car kicking out lol..had bob jane all rounders..spin out around a corner at 10kmph how annoying :?
didnt win the t5 either :shock: meh no need i like having just a cruisey car..lol has enough balls to do what i want im happy with it 8-)
Posted: Mon Jun 28, 2010 10:24 pm
Stock as a Rock
Gallery: 9 images
SA, Australia
lol yea but its no were near as fun as a manual i was cruizin along tonight on tha way home from soccer tlkn to my mate about it n was doin 60 kays dropped it down to second n jus dumped it n tha thing jus stepped out n started crab walkin its so much fun aslong as no1s out on the roads lol
Posted: Mon Jun 28, 2010 10:38 pm
Stock as a Rock
yeh manuals kick good sideways..i just dont think i could be bothered pushing in a clutch all day lol i just full lock it one way then plant it then full lock other way then fishy it..goes ok..could be more fun if manual lol
Posted: Fri Apr 18, 2014 3:36 pm
Oompa Loompa
Gallery: 14 images
Ride: MK-1 Escort, EB, XD-E-F's.
SA, Australia
Hi guys. I've just done the conversion using a 'Mal wood clutch pedal pin', and I used a 5 speed manual ECU.
I'm wondering how you stop the pedal from floping around????
The manual pedal box has a bar and switch it sits against, and the auto pedal box has nothing there, so the pedal flops up and hits the under-side of the dash ............ and it's pi$$ing me off. I really don't want to have to weld a bit of metal in under there on the pedal box so the pedal hits it, (EG - XD, XE, XF types of pedal arresters.)
I've always been a 'carbie' fan (XP-XF), and I'm just getting into the EFI's and what's different to the earlier fords. Oh I miss my old cars !!! To me, my Mk-1 Escort and my XD wagon and XF wagon are my type of car (5 speed manual conversions done to the XD and XF).
Any help greatly appreciated, and thanks for all the great help.
Posted: Fri Apr 18, 2014 3:46 pm
Ride: AU XR8
there is supposed to be a spring that goes from the clutch pedal to the firewall to keep slack out of the cable and that will also stop the pedal from coming up to far..
Posted: Fri Apr 18, 2014 5:32 pm
Oompa Loompa
Gallery: 14 images
SA, Australia
Thanks heaps for that.
Posted: Sun Apr 20, 2014 2:19 pm
Oompa Loompa
Gallery: 14 images
SA, Australia
Just wondering if someone can help with a bit of knowledge.
I've got the 5 speed in, and it's all hooked up and running. Somewhere in the wiring is a neutral safety switch bypass wire. Even in gear, or even with the gearbox loom removed, the EB still starts. I'm putting in a remote starter and want the neutral safety switch working, so am trying to find where the bypass wire is. I've checked the repair manual wiring diagram, and it says it's in there somewhere, but doesn't say where it is placed.
Help greatly appreciated.
Posted: Sun Apr 20, 2014 4:09 pm
Gallery: 6 images
Ride: ef falcon futura
Power: 154 rwkw
I don't think the manuals had a "safety switch" they have a neutral switch to tell the ecu if its in gear or not, but my factory manual I could always start in gear. you could always bridge into that switch (LHS front of box I think) so it works as a safety switch
ef futura, pacemakers, 2.5inch catback, k&n panel filter and 3.45 lsd. extractors/cat, ticky head, custom cam grind, t5. now onto cosmetics.
Posted: Sun Apr 20, 2014 9:36 pm
Ride: AU XR8
that is correct, its not a "safety switch" its just for the ecu to determine if its in gear or not...
Posted: Mon Apr 21, 2014 9:35 am
Oompa Loompa
Gallery: 14 images
SA, Australia
Ok, no worries. I called it a 'safety switch' as they had them to stop idiots starting their cars in gear, and on all the T5 conversions I've done to older fords, the neutral starter switch is hooked up on all of them. But, .... as I said earlier, I haven't dealt with the EFI's much, so if they don't have one ..... I'll add one into the loom myself I think.
Thank you for your knowledge guys. It's helped heaps.
It is currently Mon Sep 28, 2026 1:22 am All times are UTC + 11 hours
