TALES |
Heyy! Jus got a few questions as im in the dark with tha whole ford + turbo thingy. Ive recently had an A70 3.0GT Supra and am selling it as Im wanting to turbo my EF. I have a Garrett T76 turbo and Tial 50mm gate so I am atleast a bit of the way there :p Any idea on what sort of internal mods i will have done to the motor? Im thinkin of running mild boost for now. lol wish i could use my set of denso 550cc injectors but i highly doubt it! hahaha anyways does anyone know anyone in WA that has experience in turbo conversions for falcons?? Anyone from wa ever gone to turbotech?? Anyone running anythin bigger than a T76 on here?
Gaz |
standard motor will be fine on 9psi for about 200ish rwkw if its tuned right.
_________________ 2007 Steel BF Ghia MKII V8 - 19" GTP's + Superlows |
TALES |
Yer im aiming for 300rwkw :p But is that figure running a factory ecu?
66 coupe |
You can easily put upto 10psi on a std bottom end, the only thing thats going to kill it is detonation, and due to the EF running coil packs theres no real easy way to retard the timing under boost. You will need to make sure its running richer than it needs to to help prevent detonation.
You might want to contact pete (XR9Ute) and maybe the boys at BPT for some help / advise on the tuning side of things. |
TALES |
Yer I was talking to Terry about it before but maybe rather someone in perth who has done this. XR9UTE is the one with the injected 351 right? A/M ecu should cure the problem? Aswel as a set of bigger injectors and a rising rate regulator right?
TALES |
smiley235 |
Have a read of this
Its a different car but many similarities and an a/m ECU is needed for more than 200rwkw.[/url]
_________________ 178.3 rwkw
fritzz |
most ppl in perth with turbo falcons do the work them self. a few guys get there piping and tuning done at "ova boost" in malaga. the standard bottom end should be fine for 300rwkw but u might wanna stick a au head gasket in there berfore u start. to get 300rwkw i will need a good cam and a little head porting work. t76 is a bit ova board but its ur choice. most of us use a gt3540 or t66, t04z.
ive been running 13psi in my sotck engine for a while now and it still runs strong. im gonna stick it up to 15psi when my cam goes in. yes u will need an aftermarket ecu!
_________________ # 1997 EL Falcon GLI - 600+rwkw |
TALES |
Yeah sounds a lil overboard. But i purchased the turbo for 1k, 2 months old it was bought from GCG for 3 k so it'd be a waste of an awsome turbo if i wasnt to use it lol it was originally goin on my supra but i had more plans for the falcon. Can i ask how much your nizpro plenum cost?
Big Kev |
TALES wrote: Yer I was talking to Terry about it before but maybe rather someone in perth who has done this. XR9UTE is the one with the injected 351 right? A/M ecu should cure the problem? Aswel as a set of bigger injectors and a rising rate regulator right?
with the right a/m EMS you shouldnt need the reg...
_________________ For Sale: 25 Farad Rockford Fosgate Competition Series Carbon Cap, more to come - pm me if interested |
fritzz |
the plemum was 1250. good to see a nuther turbo e-series in perth!!
TALES |
Cheers fritzz! Yeah its not often you see an e series ford with a front mount sticking out :p Im interested in getting the plenum done as soon as I get the manifold! But a nice set of pistons would be awsome
fritzz |
yeh there is a few turbo e series in perth these days. i know of 5.
who u getting to do your manifold??
Kilma |
In Perth, or WA??
Defenitely good to see some more turbo 6s around. I think the S/C XR6 has you all beaten as far as I am aware, although his budget has been a lot bigger.
_________________ The fast fun: Suzuki GSXR1000
fritzz |
yeh 5 including me. turbotrana, Delta, stevo538, me, and my m8 simon.
im the only 1 that doent live in perth out of the 5. stevo538 has the most rwhp. he has 410rwhp @7psi!! on a 214,000km old engine!!
Users browsing this forum: No registered users and 6 guests |
