T2 te50 trouble starting and now stalling while driving
Page 1 of 1 [ 4 posts ]
 Post subject: T2 te50 trouble starting and now stalling while driving
Posted: Thu May 12, 2011 10:53 pm
Ride: Ford AUII TE50
Hi my t2 is having trouble starting recently the other day it was really cold it would not stay started had to keep the car moving to keep it started. but this is only sometimes and not only when its cold and not everyday. now tonight it was randomly stalling while driving. i checked fuses etc the negative cable was a little loose i tightened that. fuel filter, dry cell battery and plugs are less than 12 months old (but will be replaced soon (except battery) so that should help). it has done 184,000, high i know, but is it time to replace coils and leads? (if so what brand is good and where can i get a good set?) anything else it could be? all help appreciated, ive had enough!!
thanx
 Post subject: Re: T2 te50 trouble starting and now stalling while driving
Posted: Thu May 12, 2011 11:04 pm
Gallery: 6 images
Ah the joys of the Windsor! :)
I couldn't read much into your brief description other than to mention the basics such as the ISC or a vacuum hose may have become disconnected.
If it was a lead then you would just have a rougher engine with say, seven cylinders still running.
In my EL, I've had various failures from OEM parts like the TFI module, fuel pump, dirty ISC, fuel filter clogged, knackered MAF, stuffed leads, dud spark plug etc etc and they have all in one way or another caused crappy running. Do you have a mate who you can swap parts with to narrow down what is causing your problem?
5.6L of carbon footprint.
Posted: Fri May 13, 2011 9:18 am
Gallery: 4 images
Power: 482 rwkw
Sounds to me the car needs a GOOD service ???
When was the fuel filter serviced ???
As in ZOOM 126 edition
331 Dart block,3.25/ 4340 steel crank, Oliver rods,TFS ported track heat heads, TFS track heat inlet Twin SC61 turbo's
Project 1UZ-EF has started.. S475 Turbo 4.0 V8 Mustang Celica.....
Posted: Fri May 13, 2011 5:25 pm
Tyre Shredder
Ride: FG MK2 XR6T
Crank angle sensor? Can cause starting problems and rough running.
Formerly LV XR5 Turbo, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
Feb 2012 FG MK2 XR6 Turbo
- Manual
- Luxury Pack
It is currently Wed Oct 07, 2026 6:15 am All times are UTC + 11 hours
