T5 au conversion
Page 1 of 1 [ 9 posts ]
 Post subject: T5 au conversion
Posted: Wed Jan 10, 2018 6:56 pm
New Zealand
Hi I have a au 3 v8 and doing a conversion but have found the t5 box 20mm short at the shifter the xr6 box I have is the correct length but bell housing and input wrong, the difference in the length is the tail housing does anyone know the correct length of the au box
 Post subject: Re: T5 au conversion
Posted: Wed Jan 10, 2018 9:12 pm
Ride: '03 BA & '06 BF Wagooons
correct from where to where?
Posted: Thu Jan 11, 2018 5:30 am
New Zealand
Total length would be good and from front Bell housing to shifter
Posted: Thu Jan 11, 2018 5:42 am
New Zealand
Posted: Thu Jan 11, 2018 7:14 am
can't give you total length as i don't have a V8 bellhousing. can give you the 6 cylinder input length & length of box from front of box to centre of shifter, again 6 cylinder.
Posted: Thu Jan 11, 2018 8:00 am
New Zealand
Cheers in saying that they should be the same as I have an xr6 box and so called a au v8 box bell housing and input shaft is different but problem is tail shaft and shifter doesn’t line up with floor hole and I’m not sure if hole in gllor is different from auto to manual , I have noticed press mark in floor but again not sure and seems to be hard to find out
Posted: Thu Jan 11, 2018 10:20 am
the AU 6 & 8 use the same box housing [i believe] with the tail shaft being shorter for the manual. the EA to EL used a shorter rear housing of about 2 inches.
Posted: Thu Jan 11, 2018 1:28 pm
New Zealand
I think you are correct the box v8 one is 2 inches shorter. And now I would say from el or alike the bell housing is correct but that is bolt on , the shifter should come straight up for au ? At the moment would have to be dog legged
Thanks for your help
Posted: Thu Jan 11, 2018 4:03 pm
New Zealand
So is there a difference between the 6 and 8 t5 box the t5 xr6 box would fit perfectly the input shaft is the same as the so call v8 box but if I changed the bell housing it should fit but unsure of what affect it will have ?
It is currently Fri Sep 11, 2026 3:03 pm All times are UTC + 11 hours
