t5 Gearbox Series 2 AU XR8 220
Page 1 of 1 [ 8 posts ]
 Post subject: t5 Gearbox Series 2 AU XR8 220
Posted: Sat Sep 07, 2013 8:41 pm
Smokin em up
Gallery: 12 images
Ride: 2002 XR8 manual
Hello all again!
I have just purchased a Series 2 AU XR8 220.
I am curious to what gearbox these came out with? It's a manual T5 but i am not sure if its a Tremec box or the older Borg Warner style box.
Any info would be great!
Cheers!
AU XR8 manual.
 Post subject: Re: t5 Gearbox Series 2 AU XR8 220
Posted: Sat Sep 07, 2013 8:59 pm
Ride: 1993 EB XR8
They are the Borg Warner T5, with Tremec parts.
ILL60 - EF XR8, Sunroof, Ticky Kit, 19x8.5/19x11 TE37's, 347, AFr185's, TFS BoxRcustom converter, Hurst Quarterstick, huge billet cam.
OO0Y4 - BA2 XR6 Turbo, Nizpro Plenum, Process West stage 3 cooler, 4” dump, 3.5” exhaust, ID1000’s, ZF Auto - 11.8@116
Posted: Sat Sep 07, 2013 9:02 pm
Smokin em up
Gallery: 12 images
I see, how does that make sense? Borg Warner was working with tremec to make a combined box? What parts are tremec and what parts are Borg Warner?
Cheers.
AU XR8 manual.
Posted: Sat Sep 07, 2013 9:04 pm
Ride: 1993 EB XR8
Tremec branded case. Because IIRC, Tremec purchased Borg Warner.
Posted: Sat Sep 07, 2013 9:07 pm
Smokin em up
Gallery: 12 images
Ah I see... Did they ever get to a stage in the AU model where it was a tremec box only?
I was reading earlier and apparently some au models came with either box and the Borg Warner had a shorter final drive.
Not sure if any of this is true.
AU XR8 manual.
Posted: Sat Sep 07, 2013 9:13 pm
Ride: 1993 EB XR8
Series 3 T Series got Tremec TR3650 gearbox's. All had 3.45 diff gears.
Posted: Sat Sep 07, 2013 9:16 pm
Smokin em up
Gallery: 12 images
Ah I see... Well thanks for your help! :) clears it up a little.
AU XR8 manual.
Posted: Thu Sep 12, 2013 8:19 pm
Gallery: 12 images
Ride: DCII LTD V8
New Zealand
T5Z.
Shorter gears, and can handle more power than a T5.
I had to rebuild mine when I bought it.
{DESCRIPTION}
Trick Flow Heads/Cam/Intake, Crane Ignition, T5Z Trans.
It is currently Fri Sep 11, 2026 8:38 pm All times are UTC + 11 hours
