T5 Gearbox Problems
Page 1 of 1 [ 9 posts ]
 Post subject: T5 Gearbox Problems
Posted: Thu May 17, 2012 2:18 pm
Ride: Ford Falcon EA
SA, Australia
I jumped in the falcon the other day to go for a drive just after i had been driving it, and noticed when i put it in reverse, it got stuck in the reverse and 5th section of the box and was incredibly difficult to manage it back so i could use 1st 2nd 3rd and 4th again.
this happened to my last gearbox i had in the car but it would get stuck in fourth mainly, but also other gears too cant remember which tho. i thought it was bung so i got another for $100 wacked it in now its done the same thing.
Today i pulled down the old gearbox and all the gears looked fine so im guessing its just the gear selector mechanism? yes, no? i will say tho in input and out shaft bearings are MUNTED!
ALL HELP VERY MUCH APPRECIATED !!!
cheers Jack
 Post subject: Re: T5 Gearbox Problems
Posted: Thu May 17, 2012 3:53 pm
Gallery: 21 images
Ride: 98 EL Futura
Power: 199 rwkw
how does the pressure plate look? are the fingers warped or have decent groves in them? They can make is hard selecting gears
EL Futura: CVE head, Wolf V500, ICE Ignition and Coil, 36lb injectors, Walbro 255lb, Paci comps, 3" exhaust, T5, Harrop Truetrac with 3.9s. Now with 198.9rwkw, (~185rwkw and 13.80 @99.1mph) with more power to come
Posted: Thu May 17, 2012 4:23 pm
SA, Australia
its fine selecting the gears, clutch is fine because its only 1000km's old if that.
It doesn't get stuck in the gear it gets stuck around fifth and reverse and feels really vague as in i cant find neutral at all and is really stiff to move the gear stick.
i think it just time for a t56 if i can afford it. anymore help tho would be great
cheers Jack
Posted: Thu May 17, 2012 4:37 pm
Gallery: 21 images
Ride: 98 EL Futura
Power: 199 rwkw
found this, http://www.justanswer.com/ford/38226-89 ... -gear.html
apparently 5th and reverse syncro are the same if if its stuffed its hard to get in and out of both of those.
Posted: Fri May 18, 2012 12:43 am
Gallery: 10 images
Ride: 96 XH/97 EL
The brass rings are the same - both will most likely be worn with the teeth, but your problem is with the shifting as they use the same shifter fork. Might be the detent at the base of the gear shifter.
That article sums it up well, though.
Posted: Thu Apr 11, 2013 10:27 pm
Ride: XR6 AU II 2001
SA, Australia
also if you have a t5 gearbox (unfortunetly like this guy said the synchros) There is a pretty reasonably priced manual kit (short throw) for those boxes thats quoted to protect your syncros from damage and improve shift time between gears by 40%...
I just can't remember where i saw it (which is damn annoying as i wanna get one myself)
Posted: Fri Apr 12, 2013 9:24 am
Smokin em up
Gallery: 3 images
Ride: EL Fairmont
Power: 12 rwkw
SA, Australia
http://www.gmmotorsport.com.au/products ... -6cyl.html
EL Mont- mods: 2.5" catback, clear indicator repeaters.
Planned mods: Boooooooooooooossssssssst :D
Posted: Fri Apr 12, 2013 9:40 am
Smokin em up
Gallery: 3 images
Ride: EL Fairmont
Power: 12 rwkw
SA, Australia
Also these too... http://www.mgwltd.com/mustang_shifter.shtml
Posted: Sat Apr 13, 2013 6:04 pm
Ride: '03 BA & '06 BF Wagooons
what about this
{DESCRIPTION}
It is currently Wed Sep 16, 2026 3:02 pm All times are UTC + 11 hours
