t5 gearbox rebuild write up ???
Page 1 of 1 [ 4 posts ]
 Post subject: t5 gearbox rebuild write up ???
Posted: Thu Jun 19, 2014 12:00 am
Tyre Shredder
Gallery: 5 images
Ride: EL GLi
anyone know where there is a t5 gearbox right up looking to rebuild a t5 gearbox soon as a project had a quick surf n couldnt see watched {DESCRIPTION} but they didnt show how to do the reverse gears.
 Post subject: Re: t5 gearbox rebuild write up ???
Posted: Thu Jun 19, 2014 1:55 pm
Gallery: 22 images
Ride: AU2 XR8 ute & 91 EA bitsa
Look under AutoRestomod for T5 teardown and assembly on youtube. Also, read through the repair manuals and get a pdf of the Tremec document (which is easy to find on the net).
Have you got a shop press and bearing clamps to remove the gears and bearings?
The countershaft and reverse gear idler are easy to get out once the mainshaft is removed.
AU2 XR8 with Raptor VL, ported Yella Terra GT40P heads, Scorpion 1.6 RRs, XE264HR-14 Comp Cam, ceramic coated Hurricane Headers, 60lb injectors, Walbro 255, 200cfi cats, 3" exhaust & Snow Performance water methanol injection
Posted: Sat Jun 21, 2014 11:36 pm
Tyre Shredder
Gallery: 5 images
Ride: EL GLi
the link given was there video il get the pdf n read it yeah iv got a press i can get a bearing clamp i suppose
Posted: Sun Jun 22, 2014 7:04 pm
Gallery: 22 images
The link you posted was the main one I used. Three things to remember when doing the rebuild:
1. Use ATR when pressing parts on or off. I jammed the 5th gear onto the mainshaft and had to cut it off using a grinder. Should have lubed it with ATR first.
2. Mark the 1-2, 3-4 and reverse synchroniser sleeves and hubs before you pull them apart
3. Make sure the retainer springs hook into the same key and run clockwise on both sides of the synchronisers
It is currently Mon Oct 05, 2026 4:01 pm All times are UTC + 11 hours
