T5 Manual on an AU falcon and 2300kg towing capacity.
Page 1 of 1 [ 3 posts ]
 Post subject: T5 Manual on an AU falcon and 2300kg towing capacity.
Posted: Mon Sep 23, 2013 1:53 pm
Parts Gopher
Ride: Ford Falcon AUII
Hey all,
I have a Series II AU falcon with the standard auto box and a heavy duty 2300kg towbar installed (which is occasionally used to full extent with a car trailer). I am quite interested in putting in a manual conversion to a T5 gearbox, but i'm concerned as to the reduced towing capacity on manual AU falcons.
Can anyone confirm if the T5 could hold against a car-trailer, IE: will I be able to maintain my 2300kg towing capacity?
Thanks, Thomas.
My Megasquirt 3 install: {DESCRIPTION}
 Post subject: Re: T5 Manual on an AU falcon and 2300kg towing capacity.
Posted: Mon Sep 23, 2013 3:29 pm
Ride: 93 ED sedan
Power: 161 rwkw
I don't know why it is reduced.....but....you won't be towing in 5th....have to use 4th.
I towed a car from Geelong to here, with my ED with an EA T5, with 3.27 diff gears.
I was sitting around 3,000 to 3,200 rpm in 4th at 110 kmh....towed really well.
I was getting around 450km to a tank at that.
http://youtu.be/jJTh9F3Vgg0
Posted: Mon Sep 23, 2013 3:34 pm
Gallery: 11 images
Ride: EL Fairmont, VFR400 racer
Power: 144 rwkw
I towed a boat with the EL Fairmont when the T5 was in. I think the boat/trailer was about 1.7t with 4 people in the car and some tools. As cjh said, I towed in 4th most of the time, although when I got on the freeway it was in 5th until hill climbs. Fuel consumption went through the roof though...something like 400km/tank compared to my 600km. T5 has held up after doing that about 6 times.
phongus = Post whore 2006
EL XR6 motor, EL ECU + J3 chip, WADE 1673 Camshaft, 3" S/S intake, Pacy 4480, 2.5" Hi flow cat, 2.5" Lukey exhaust.
Max Power = 144.6 rwkw (03/05/2008)
It is currently Tue Jul 21, 2026 9:15 pm All times are UTC + 11 hours
