T5 v8 bellhousings
Page 1 of 1 [ 3 posts ]
 Post subject: T5 v8 bellhousings
Posted: Sat Nov 19, 2016 10:35 pm
Gallery: 8 images
Ride: EL XR6
Hi all,
Does anybody know if a t5 v8 bellhousing off an AU will fit a e series v8 t5?
Second question, will a v8 t5 bellhousing fit a 6 cyl t5?
El XR6 Turbo
Dark Agents,Sunroof, bilstein shocks, 6000k HIDS, 329 mm slotted rotors, twin pot calipers , Climate Control, GarrettT04 turbo,log manifold, crow turbo cam, microtech lt10c, 42lb injectors , 044, surge tank , T56 , rebuilt bottom end , alloy plenum .
Aiming for 300 rwkw
 Post subject: Re: T5 v8 bellhousings
Posted: Mon Nov 21, 2016 2:01 pm
Gallery: 7 images
V8 T5 bellhousings (E and AU Series) should be the same.
But no - wont work with the I6. The input shafts are a different size. Also the AU and E Series 6 cyl housings are different
Nigel
Posted: Mon Nov 21, 2016 2:13 pm
Gallery: 8 images
Ride: EL XR6
Thanks for that. The gearbox shop in Sydney can extend the 6cyl input shaft. it's a shame the front housings are different. Would make fitting a 6cyl box easier without having to buy a dellows bellhousing.
I have a au v8 bellhousing and picking up a Ed xr8 t5 so I should be all sorted.
El XR6 Turbo
Aiming for 300 rwkw
It is currently Mon Oct 19, 2026 11:42 am All times are UTC + 11 hours
