T5 XF?
Page 1 of 1 [ 8 posts ]
 Post subject: T5 XF?
Posted: Wed Apr 30, 2014 11:04 pm
Gallery: 1 images
Ride: EB falcon 5lt
Will a T5 from an e series falcon bolt up to a 250 x-flow in an xf? I.E. bell housing. I want to put a T5 into my XF ute and can get a T5 out of an e series cheap but need to know if it will bolt up or not.
 Post subject: Re: T5 XF?
Posted: Wed Apr 30, 2014 11:14 pm
Gallery: 4 images
Ride: 5.0 AU's and 5.0 Maverick
Power: 139 rwkw
Nope. they are different.
More people paid for a ride in a VT commodore then an AU Falcon so the VT is superior.
Based on that fact my Mum is the best around!
Posted: Wed Apr 30, 2014 11:15 pm
Gallery: 1 images
Ride: EB falcon 5lt
Damn. Is it just a case of changing a bell housing?
Posted: Thu May 01, 2014 2:14 am
Stock as a Rock
Gallery: 6 images
you can use the bellhousing from the 250 crossflow. 3 of the holes line up then drill n tap the fourth hole .by memory I think you need a gearbox mount from a xg. been a loooong time since I did one
Posted: Thu May 01, 2014 11:09 am
I had an EL T5 in my XF with the XF T5 bell housing.
Any T5 will bolt up. The only things that change on a T5 are input/output shaft length, number of splines, and shifter location.
EL Fairmont Ghia - Manual - Supercharged
- {DESCRIPTION}
- {DESCRIPTION}
Posted: Thu May 01, 2014 5:31 pm
Stock as a Rock
Gallery: 6 images
you don't have to change anything on the t5. if the XF was already manual it will be a strait bolt up once the 4th hole is done on the bell-housing . the splines input/output shaft are all the same. you can still use the original tail-shaft out of the XF
Posted: Thu May 01, 2014 5:37 pm
Sorry, I meant in general, and worldwide Ford T5's
All the different configurations of T5 used in any Ford worldwide, the gear case remains the same and will bolt up to any other T5 bell housing.
I thought the big hole in the single-rail bell housing needed to be machined a bit larger to fit the T5 input bearing retainer. Handy to know if that's not the case.
- {DESCRIPTION}
- {DESCRIPTION}
Posted: Thu May 01, 2014 6:02 pm
Stock as a Rock
Gallery: 6 images
all good .the t5 in the e-series will fit in the old bell-housing behind the 4.1l motor. I believe the mustang t5 is slightly bigger.
It is currently Thu Sep 24, 2026 5:53 pm All times are UTC + 11 hours
