krisisdog |
Still a 5spd
MICKYYYY |
krisisdog wrote: Still a 5spd Give us a good reason why he needs a 6 speed???
_________________ Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc[/SIZE][/size][/color] |
67RCE |
MICKYYYY wrote: krisisdog wrote: Still a 5spd Give us a good reason why he needs a 6 speed??? Becuase even a G-Force box will strip 3rd after it's been given enough. Go TKO or T56!
_________________ ILL60 - EF XR8, Sunroof, Ticky Kit, 19x8.5/19x11 TE37's, 347, AFr185's, TFS BoxRcustom converter, Hurst Quarterstick, huge billet cam. |
capare |
67RCE wrote: MICKYYYY wrote: krisisdog wrote: Still a 5spd Give us a good reason why he needs a 6 speed??? Becuase even a G-Force box will strip 3rd after it's been given enough. Go TKO or T56! And you know this how? |
Dansedgli |
BI6TIM had one I think.
Let us know how the fancy T5 goes once its behind the motor. There isnt much point telling everyone how good they are when its not in yet. |
Dansedgli |
This guy broke 3rd in one. On the next car he built he went for a T56.
http://www.boostedfalcon.net/viewtopic. ... ox#p126526 ed_fairmont_turbo wrote: The box i'm using now is a gforce transmission t5 with aftermarket reinforced case, high grade nikkel steel mainshaft that is a must for 500hp+, semi-straight high nikkel steel synchro gears that are alot thicker than standard, another good thing is that all the gears can be changed so even though i've broken 3rd it can be changed without replacing the whole cluster set. And it all cost me under $3000 delivered to my door
Herse's are the site i bought it from: http://www.gforcetransmissions.com/tran_gt-5.asp I haven't got the gearbox out yet to see why i've broken a tooth but should do this afternoon, i will put some picks up of my discovery |
MICKYYYY |
67RCE wrote: MICKYYYY wrote: krisisdog wrote: Still a 5spd Give us a good reason why he needs a 6 speed??? Becuase even a G-Force box will strip 3rd after it's been given enough. Go TKO or T56! Of course TKO or T56 is the way to go but the question i asked is who needs a 6 speed???
krisisdog |
Do spend the same money, and end with a 6spd thats stronger or 5spd thats still weaker?
Hmmm. |
marxr8 |
so you guys recone its ok to gear boxes of ebay iv heard a few night mare stories thats all
_________________ Thats a sweet ride you got there! don't tuch it, dont even look at it |
MICKYYYY |
krisisdog wrote: Do spend the same money, and end with a 6spd thats stronger or 5spd thats still weaker? Hmmm. T56 is more expensive over TKO and they hold about the same power..................
krisisdog |
How much is a TKO?
ed_fairmont_turbo |
well that guy that broke the g-force trans 3rd gear would be me, thats was some time ago in my stolen car. The gearbox was really was a dream to have but to be honest i had the chance to do it all again and i went for the t56 and it worked out to be less than $2k
_________________ ED Fairmont: Master Power GT45, race spec T5, Wolf v4, 870cc Injectors, EF bottom end, EF Head, Surcam custom Grind Cam, Crane LX92 Coil |
Benno The Viking |
I ebayed T56 Tremec 6 Speed, and these 2 listings stood out at me.
http://cgi.ebay.com.au/Tremec-T56-6-speed-gearbox-/130509505956?pt=AU_Car_Parts_Accessories&hash=item1e62f905a4 Here's a T56, from a Commy, 40,000 ks, 8 days to go from the 17th April, it's $1,800. http://cgi.ebay.com.au/6-SPEED-MANUAL-GEARBOX-TREMEC-T56-VZ-SS-COMMODORE-5-7L-/320684561462?pt=AU_Car_Parts_Accessories&hash=item4aaa4a1436 Here's another one for sale, bidding is around 510 dollars so far. If/when my auto goes pop in my EL, I was going to try to get one of these for it, so I can turbo or supercharge it in the future if I want, I'm not sure if I'll be able to afford it but we can all dream.
_________________ Build Thread |
Users browsing this forum: No registered users and 37 guests |
